College Year 1 Physics/Chemistry?
  • Thread starter Thread starter geft
    College Year
For those seeking recommendations on introductory physics books with a calculus focus, "University Physics" is highlighted for its detailed explanations and manageable end-of-chapter problems. However, it tends to minimize the use of calculus, addressing it only when necessary, which may not meet the needs of all learners. For a more calculus-intensive approach, "Halliday & Resnick" is suggested as a strong alternative, reputed for its comprehensive integration of calculus concepts in physics.
geft
Can someone recommend me some good books of those subjects?
EDIT: Sorry, I meant calculus, not chemistry.
Well, can't really tell much but I'm guessing you're looking for a Calculus-based introductory Physics book?
If you're more worried about the physics of it, imo, I found University Physics a really good book, explains everything with tons and tons of detail without much waste surprisingly, and the end of chapter problems are pretty good as well, not easy by any means but not so hard that they frustrate me to no end trying to solve them.
Only problem for you might be the lack of Calculus in it, there is some when neccesary but I found that it tries to ignore it sometimes and there's not much emphasis on it, like for example, in the motion chapter, they talked about instantaneous velocity/acceleration etc. but only ~3 questions out of 100+ actually made use of it.
If you want more Calculus, might want to take a look at Halliday & Resnick, haven't used it so I won't comment but supposedly it's really good and has a ton more calculus.
The book is fascinating. If your education includes a typical math degree curriculum, with Lebesgue integration, functional analysis, etc, it teaches QFT with only a passing acquaintance of ordinary QM you would get at HS. However, I would read Lenny Susskind's book on QM first. Purchased a copy straight away, but it will not arrive until the end of December; however, Scribd has a PDF I am now studying. The first part introduces distribution theory (and other related concepts), which...
I've gone through the Standard turbulence textbooks such as Pope's Turbulent Flows and Wilcox' Turbulent modelling for CFD which mostly Covers RANS and the closure models. I want to jump more into DNS but most of the work i've been able to come across is too "practical" and not much explanation of the theory behind it. I wonder if there is a book that takes a theoretical approach to Turbulence starting from the full Navier Stokes Equations and developing from there, instead of jumping from...
