Calculating the max distance of compression of the spring HELP
urgent
Calculating the max distance of compression of the spring please HELP!
A 2.0 kg block is dropped from a height of 40 cm onto a spring of force constant k = 1960 N/m. The maximum distance the spring is compressed is?
I Used the equation W=mgh and W=1/2kx^2..
i did..
W=2*9.8*0.4
=7.84
then i used
7.84=1/2*1960*x^2
from which i got x=0.0894427191
then i did
7.84*0.0894427191=0.7012309177
then i did
7.84-0.7012309177=7.13879
can anyone please help me tel where i went wrong? because the answer to this question is 10 but i don't know how to get it..please help=].
There is extra gravitational potential energy from the distance through which the spring drops through while touching the spring. In other words, the total distance that the object drops is 40 cm plus however far the spring compresses.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
