Weyl Tensor Components in n-Dim Manifold: N=3?
paweld
I found the formula for the number of independent components of
Weyl tensor in n-dimensional manifold:
<br /> (N+1)N/2 - \binom{n}{4} - n(n+1)/2~~~~~N=(n-1)n/2<br />
This expression implies that in 3 dimension Weyl tensor has 0 independent
components, so it's 0. Does it implies that any three-dimensional manifold
is conformally flat (maybe the formula I've written above is incorrect for n<4)?
WP has some infromation that seems relevant: http://en.wikipedia.org/wiki/Weyl_tensor
The Weyl tensor has the special property that it is invariant under conformal changes to the metric. That is, if g′ = f g for some positive scalar function f then the (1,3) valent Weyl tensor satisfies W′ = W. For this reason the Weyl tensor is also called the conformal tensor. It follows that a necessary condition for a Riemannian manifold to be conformally flat is that the Weyl tensor vanish. In dimensions ≥ 4 this condition is sufficient as well. In dimension 3 the vanishing of the Cotton tensor is a necessary and sufficient condition for the Riemannian manifold being conformally flat. Any 2-dimensional (smooth) Riemannian manifold is conformally flat, a consequence of the existence of isothermal coordinates.
Physically, I would associate the Weyl tensor with the existence of tidal forces, which conserve the spatial volume of a free-falling cloud of particles. In 2+1 dimensions, this can exist. In 1+1, it can't. From the WP article, it sounds like maybe the Cotton tensor, rather than the Weyl tensor, is the appropriate way to measure tidal forces in 2+1...?
Thanks for answer. The vanishing of Weyl tensor is nessesary condition but not sufficient
for a metric to be conformally flat. In dimension >=4 it turns out to be also sufficient
condition but in lower dimensional manifold it is not.
In Wiki article http://en.wikipedia.org/wiki/Weyl_tensor#Conformal_rescaling
about Weyl tensor there is said that metric is conformally flat if it fullfil some PDE
and in dimension >=4 the only integrability condition for this PDE is Weyl tensor=0.
Maybe someone knows what this PDE has in common with conformal flatness.
I have no idea, but it looks interesting.
I'm also looking for simple prove that conformal mapping doesn't change Weyl tensor
(I would love to find geometrical argument, but probably it's imposibble).
Thanks for help
Thanks for help
There is no other alternative to the proof of this theorem. Actually it is all clear that a conformal transformation of metric tensor, i.e. \bar{g}_{ab}=e^{2\lambda}{g}_{ab}, with \lambda being a scalar function of coordinates x^{a} using a direct calculation, including the expansion of Christoffel symbols and Riemann tensor in the new coordinates, leaves the Weyl tensor unchanged and this all doesn't exceed two ordinary textbook pages.
See e.g. Riemannian Geometry, E. P. Eisenhart, Princeton Press 1949, pp 89-90.
There's already a formula to calculate the number of the independent components of the WT and it is
\frac{1}{12}n(n+1)(n+2)(n-3)
which gives 0 for n=3 and obviously works fine for n's greater than 2. I don't know how you manage to derive your formula but if it works for any given n, you should first consult an expert and then think of a suitable journal to publish it in (though I for one am sure it has nothing new to tell but as a tacit work can be good.)
Nupe. Any three dimensional pseudo-Riemannian* manifold is conformally flat iff the third order http://en.wikipedia.org/wiki/Cotton_tensor" vanishes.
* (this must be pseudo-Riemannian Weyl tensor is a measure of the pseudo-Riemannian manifolds)
AB
Thanks for your answer.
My formula is completely equivalent to yours - I've factorised mine and got the same result.
Maybe you know why in dimension >=4 metric is confomally flat iff Weyl tensor=0
See e.g. Riemannian Geometry, E. P. Eisenhart, Princeton Press 1949, pp 91-92.
If you hit anything difficult to catch on, simply ask it here!
AB
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
