A Quick Question on Compton Scattering
j-e_c
1. A photon of wavelength 1.000nm is scattered by a muon initially at rest. What is the deflection angle of the photon if its wavelength after scattering is 1.001nm?
\lambda^{'} - \lambda = \frac{h}{mc} (1 - cos(\vartheta)
Assume that the mass of the muon is 200 times that of an electron.
I have got down to cos(\vartheta) = -81.4. I'm not sure what to do now.
That's not good. Getting |cosθ| > 1 is a sure sign that you've made an error somewhere.
Redo your calculation. (Show what you plugged in where.)
Thanks for the quick reply.
Note - I'm going to change theta to x so I can avoid LaTeX complications. Similarly, I'm going to change lambda to a and lambda-prime to b.
First, I rearranged the equation to make cos(x) the subject:
(b - a) = h/mc (1 - cos(x))
(b - a)mc/h = 1 - cos(x)
1 - [(b - a)mc/h] = cos(x)
Now, I'll show you how the value came about:
b - a = (1.001 - 1.000)x10^-9
= 1.000x10^-12 (1)
mc/h = (200 x 9.11x10^-31 x 3x10^8) / (6.63x10^-34) = 8.244x10^13 (2)
Multiplying (1) and (2) I get 82.44
Then 1 - 82.44 = -81.44
Therefore cos(x) = -81.44
Your calculation looks OK to me. That tells us that the assumptions of the problem are not consistent with Compton scattering. You can't have the given change in wavelength when scattering off of a muon! (Either that's a trick question or I'm missing something basic. :rolleyes: I'll think about it.)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
