Estimating Energy Generated by Niagara Falls
  • Thread starter Thread starter physics(L)10
    Energy
To estimate the energy generated by water falling over Niagara Falls in five days, the calculation begins with the height of 150 meters and a water flow rate of 104 m³/sec. The total time for the five days is calculated as 4,320,000 seconds. The potential energy is determined using the formula P = W/t, where W is the work done, calculated as mgh. The mass can be found by converting the flow rate into mass using the density of water, approximately 1000 kg/m³. This method provides a comprehensive approach to estimating the energy produced by the falls.
physics(L)10
Estimate E generated by water falling over Niagara falls in 5 day.
Height = 150m
Water flow =104m3/sec
t=5x24x60x60=4320000sec
P=W/t
mgh=mv2/2
Work=mgh=m(9.8)(150)
Time=432000seconds
P=m(1470)/4320000
I just don't know how to convert 104m3/sec into a mass
The density of water is ~1000kgm^{-3}.
You can use this to work out the mass flowing per second.
Alright niceee thanks for the help :)
No problemo :)
