Integrating by parts in path integral (Zee)
GreyBadger
Hi all,
I have an exceptionally basic question, taken from P21 of Zee. Eq. 14 is
Z=\int D\psi e^{i\int d^4x(\frac{1}{2}[(\partial\psi )^2-m^2\psi^2] + J\psi)}
The statement is then made that 'Integrating by parts under the \int d^4x' leads to Eq. 15:
Z=\int D\psi e^{i\int d^4x[-\frac{1}{2}\psi(\partial^2+m^2)\psi + J\psi]}.
Now, I am being supremely thick, but I don't see how this follows. Could somebody please spell it out in small words?
Consider the Green's identity equation (4) in the link which is basically a 3D version of integrating by parts:
http://mathworld.wolfram.com/GreensIdentities.html
and taking the surface integral to be zero implies that
\int dV \;\nabla \phi \nabla \psi = -\int dV \;\phi \nabla^2 \psi
and so in this example, one can extend that to 4D and take the volume boundary term to zero
"Partially integrating" means here that you use partial differentation to rewrite the integrand.
Here the relevant term becomes
<br /> \int_{\Omega} \partial \phi \partial \phi = \int_{\Omega} \partial(\phi\partial\phi) - \int_{\Omega} \partial^2 \phi<br />
The first term on the RHS becomes
<br /> \int_{\Omega} \partial(\phi\partial\phi) = \int_{\partial\Omega} \phi\partial\phi<br />
by Stokes theorem. Imposing boundary conditions, this term vanishes.
Aha yes. Thank you both.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
