Solve Lagrange Multipliers for x,y,z in Min Distance Problem
kliker
find the points on the surface x^2-z^2 = 1 which are in minimum distance from (0,0)
i should find the points using d = x^2+y^2+z^2
first of all
gradf = λ gradg
where f = d and g = x^2-z^2
so we have (2x,2y,2z) = λ (2x,0,2z)
now
2x = λ2x
2y = 0 => y = 0
2z = λ2z
so λ=1
but now how can i find x and z?
im totally confused
i would check your grad g
also i think you mean closest to (0,0,0)?
first of all
gradf = λ gradg
This s wrong. You have dropped a sign.
now
2x = λ2x
2y = 0 => y = 0
2z = λ2z
so λ=1
im totally confused
oh you're right so now i have
2x = λ2x
2y = 0 => y = 0
2z = -λ2z => λ*2z+2z = 0 => 2z(1+λ)=0
hence we have λ = -1 and z = 0
but if z is 0 then x = +1 or x = -1
so for λ = -1 we have two points (1,0,0) and (-1,0,0)
is this correct? also, i would like to ask something, if these points are correct then why for λ = -1 in the first equation i get -4x = 0 hence x = 0?
but when x = 0 the point will be (0,0,0), can we check for this point too?
thanks for your help
(0,0,0) is not in your surface
its also worth drawing the surface to help understand what is going on
try drawing the curve given by y=0, x^2-z^2 = 1 in the xz plane...
Just curious, shouldn't d = sqrt(x^2+y^2+z^2)
yeah, but minimising x^2 will minimise |x| so its ok - but i suppose you should show it
the problem states by itself that it shouldn't be sqrt(x^2+y^2+z^2) I think i understand the solution now,
thanks for your help :)
