Charges set on 4 corners of a square
jbirse
Three point charges +Q are placed at three corners of a square, and a charge -Q is placed at the fourth corner. If Q = 1.00 milli-coulomb and the side of the square has length 1.00 m, find the magnitude of net force that the positive charges exert on the negative charge. |F|=
F = kq1q2/d2
k = 8.99 x 109 N-m2/C2
I've tried this problem three times and i only have 2 more attempts to get it right so can anyone help me with this?
Sure, we can help you, but show us what work you've done on it first.
You have to use pythagorean theorem to first find the total force F by the 2 charges adjacent to the negative charge. This force F would lie on the same direction as the force from the 3rd positive charge (and that is because the forces from the 2 adjacent charges are both equal in magnitude and vertical to each other) so to find the net force u just add F and the force from the 3rd charge.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
