Special Relativity and the Particle-Antiparticle Problem
Anamitra
In Quantum Mechanics we have the possibility of particles shooting across a space-like interval (the probability amplitudes of the particles get canceled by those of the antiparticles shooting across in the reverse direction as seen by an observer in the boosted frame). I have found this fact in
1) Michael Peskin's "An Introduction to Quantum Field Theory" Chapter 2[The Klein Gordon Field],Subsection 2.1,The Necessity of the Field View Point.
2)Steven Weinberg's "Gravitation and Cosmology", Chapter 2[Special Relativity],Section 13,Temporal Order and Antiparticles
My Problem:
We consider such an interval in the unprimed frame given by the space-time coordinates (t1, x1) and (t2,x2) where,
(x2-x1)/(t2-t1)=k>c
We assume t2>t1
In the primed frame,
x1’=gamma (x1-vt1)
t1’=gamma(t1-(v/c^2)x1)
x2’=gamma (x2-vt2)
t2’=gamma(t2-(v/c^2)x2)
t2’-t1’=gamma[(t2-t1)-(v/c^2)(x2-x1)]
=gamma(t2-t1)(1-k(v/c^2))
Temporal reversal takes place in the primed frame provided,
k>c^2/v
We consider an unprimed frame which belong to the category
c<k<c^2/v
Such frames pertain to space-like intervals in the unprimed frame whose temporal coordinates do not get reversed in the primed frames. Let us categorize such frames(in the primed systems) as ”Class A”
My queries: How do they explain the particle-antiparticle problem in relation to the Class A frames? Do the particles and the antiparticles travel in the same direction for these cases and still their amplitudes cancel?Do these frames really cause any confusion?
It is important to note that space-like separations in the unprimed frame do remain space-like separations in the primed frame in relation to the “CLASS A “ category [despite maintenance of temporal order] This may be easily verified by simple calculations.
I am not getting any reply even after a long time.I am feeling more and more confused!
It would help if you would mark up your math in LaTeX. Personally, I'm disinclined to spend a lot of time deciphering a long, mathematical post that isn't rendered in my browser as equations.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
