Bernoulli's principle with venturi effect
The discussion focuses on calculating the vacuum pressure at a specific point in a project utilizing Bernoulli's principle and the Venturi effect. The user seeks to understand how the suction at the inlet will affect airflow, particularly whether it can increase from 500 CFM to a higher value. It is noted that mass flow remains constant across any cross-section, and CFM can only increase with significant changes in temperature or pressure that reduce gas density. Additionally, friction within the pipes and gas viscosity will cause pressure drops, affecting overall performance. Accurate calculations are essential for optimizing the system's efficiency and achieving desired airflow rates.
Diokaef
So, I need some info on how to get the data that I'm missing on my project.
My english is not great and is very hard for me to try figure this out by myself so if you guys could help me out I will appreciate.
I need to know how much vacuum in HG I will get at the B on my picture, and if will increase the suction from my B inlet (500 CFM at 700F) mean increase its velocity output from 500CFM to ?
I will be using fans to provide a 75mph wind at the A inlet then reduce the pipes until I can divide that to 12 hoses with inside of 1/8" 36" long to a collector kind thing then will flow around of a 2 1/4" pipe, on this pipe I have already a 500CFM at 700F and I need to know how much if any increase would have at that stage (ex. 500 CFM increase to 700 CFM)
Man, I'm really having problems with this thing.
Mass flow across any cross section in this device will be constant. CFM will only increase if the temperature increases enough or pressure decreases enough to create a significantly large decrease in density.
Assuming this is a real device, then pressure will decrease even in the constant diameter section of pipes, due to friction with the walls of the pipes, and viscosity (friction within the gas itself).
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
