Average wavelength for blackbody radiation
The maximum wavelength for blackbody radiation is determined by the formula 0.29/Temperature, but there is no singular "maximum" wavelength. The average wavelength at a given temperature is sought, with the assumption that it may be 1.84 times the maximum wavelength. To calculate the average wavelength, Planck's Law can be applied, integrating the power of blackbody radiation over all wavelengths. The discussion references the relationship between peak and average wavelengths, suggesting a factor of 1.76 between them. Understanding these calculations is essential for accurate interpretations of blackbody radiation.
jimjohnson
The maximum wavelength for blackboby radiation is .29/Temperature. Is the average wavelenght 1.84 times the maximum for all temperatures?
Science news on Phys.org
As shown in both ref., the wavelength where the emission intensity is maximum is .29/T. But I want to know the avg wavelenght at that temperatue. So I think the wavelenght where the area under the intensity ghaph is equal on both sides would be the average, but I do not know how to calculate it from gragh equation. My estimate working back from other calculations was 1.84 times the max wavelenght.
You can calculate the following:
Use Planck's Law for the blackbody radiation power as a function of T and λ
http://en.wikipedia.org/wiki/Planck's_law
u(T,λ) = [2hc25]/[e(hc/λkT) - 1]
The average wavelength is then given by:
λavg = ∫λ u(T,λ) dλ / ∫ u(T,λ) dλ
where both integrals are from 0 to ∞. The appendix of the above wiki solves the important integrals.
Bob S
Do you know if the average is 1.84 the maximum for all temperatures? I can not do the math. The following quote from the source may relate: This function peaks for hc = 4.97λkT, a factor of 1.76 shorter in wavelength (higher in frequency) than the frequency peak. Thanks jimj
