Calculating Probability of Receiving $1 from Multiple People
  • Thread starter Thread starter damajha
    Probability
To calculate the probability of receiving at least $1 from Bob, Ted, and Frank, each with a 30% chance of giving a dollar, the formula is 1 minus the probability that none will give a dollar. The probability that none will give a dollar is calculated as 0.7 (the chance of not receiving a dollar from each person) multiplied together: 0.7 x 0.7 x 0.7. This results in a 65.7% chance of receiving at least one dollar, confirming the calculation. Understanding this approach allows for solving similar probability problems effectively.
damajha
Should be simple enough... unfortunately I'm 20 years removed from college and can't seem to find an equation so I thought I'd post it here.
If there is a 30% chance that Bob will give me a $1, and a 30% chance that Ted will give me a $1 and a 30% chance that Frank will give me a $1. What are the chances that at least one of them gives me a $1?
Very hypothetical, but if someone could give me the equation to solve it then I can figure some other problems out on my own.
Thanks,
Dale
The chance that at least one will give you a dollar is 100% minus the chance that none will give you a dollar. The chance that none will give you a dollar is the chance that the first won't give you a dollar times the chance the second won't times the chance the third won't.
So... if I get this straight
1 - (.7 x .7 x .7) = 65.7% ?
Yup, or you can look at all the combinations that can occur, e.g. Bob gives you a dollar and Ted and Frank don't, and so on, and then sum the appropriate probabilities.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
