How Can I Maximize Output with LM331 Multiplier for Power Meter Design?
  • Thread starter Thread starter syee10
The discussion centers on designing a power meter using the LM331 multiplier to accurately calculate power by multiplying voltage and current signals. The user faces challenges with the LM331's transfer function, which does not yield the expected output of 6W for given inputs of 3V and 2A. Participants suggest that proper conditioning and scaling of the input signals are essential to achieve the desired output, emphasizing the importance of ensuring that the maximum power measurement aligns with the LM331's 10V full-scale output. The conversation highlights the need for adjustments in the circuit design to meet the specific output requirements. Overall, achieving accurate power measurement with the LM331 requires careful input signal management.
syee10
Hi,
I am designing a power meter which using the multiplier LM331 to multiply the Voltage and Current signal. The voltage and current signal will be go through the sample and hold circuit and the output of the sample and hold will be go into the LM331 multiplier. Power, P=VIcos(angle) and the LM331 having a transfer function of output W = [(X1-X2)(Y1-Y2)/10V]+Z. The problem is for example V=3V and I=2A, Output should be 6W(ignoring the cos(angle)). Due to the transfer function of LM331 i will never get the output 6W that i want. So anyone there can help me out? =)
syee10 said:
Hi,
What do you get for the output in your example? It looks like full scale is 10V? So what are the limits of your input signals?
The multiplier scale the output to 10V..means the output i suppose to get is 10 but it scale to 1. What i need is a multiplier that multiply a signal with another signal and i get the exact output of both inputs. My task is actually get the power of input Voltage and input Current by using a multiplier.
You need to condition and scale your inputs, so that you get the max of 10V at the output for the max power that you expect to be measuring. Scaling is all part of making a circuit like you are describing. What is the max power you want to measure (which will give you the 10V full scale output)?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
