How Does Raising Air Pressure in a Flask Affect Temperature and Maximum PSI?
A biologist inquired about the effects of using a 100 psi air compressor on a one-liter glass flask filled with air, specifically regarding pressure and temperature changes. It was suggested that the pressure could increase by 100 psi, leading to a temperature rise proportional to this increase. However, a correction was made regarding the application of Boyle's law, clarifying that it only applies to a fixed mass of gas. The actual temperature of the gas would be influenced by the outlet temperature of the air compressor, which varies based on several factors. The discussion highlighted the complexities of gas behavior under compression and the importance of considering these variables.
Batata
Hi! I'm a biologist so be easy on me:)
Say I had a one liter glass flask filled with air and I had a 100 psi air compressor attached to it. (I don't want to suck air out but blow more inside!) How would the air in this flask react - according to the law of ideal gas the temperature of the air should start rising, but would I be able to increase the pressure in the flask as well? How much would I be able to raise the psi in the flask?
Thanks!
i think if you had a 100PSI compressor, you could raise the pressure by 100PSI.
the volume would remain the same, so T would go up by the same factor.
100PSI is 14 times atmospheric pressure, so the temperature would increase by a factor of 14.
but I'm not 100% sure. hopefully someone else can either confirm I'm correct, or let you know what i did wrong.
dnp33
I'm sorry you are wrong, you seem to be applying Boyles law P1*V1/T1=P2*V2/T2 but this only works for a fixed mass of gas. The temperature of the gas in the flask in this instance would be about the same as the outlet temperature of the air compressor, which would depend on a huge number of factors.
ah i see.
thank you for the correction, i seem to have missed the fact that there was obviously air being pushed into the flask.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
