Does application of torque add to rotational stability?
Applying torque through engine braking enhances the rotational stability of a motorbike when descending a steep hill. In contrast, riding out of gear without brakes leads to increased instability due to the lack of control over the bike's speed and direction. As speed increases, the bike's stability also improves, but this is contingent on maintaining control through torque application. Therefore, using engine braking while in gear is crucial for maintaining stability at higher speeds. Overall, torque application significantly contributes to the bike's stability in steep descents.
AJ_2010
Case in example:
If a motorbike is being riden down a steep hill and out of gear with no brakes applied; would this be more unstable than if the bike were in-gear using engine braking?
(Above condition being at the same speeds).
The faster the bike is moving the more stable it is right
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
