Magnetic Field of Rotating Cylinder w/ Linear Polarization
The discussion focuses on calculating the magnetic field (B) of a rotating dielectric cylinder with linear electrostatic polarization (P) proportional to the radial distance (P = αr). The cylinder's rotation is characterized by an angular velocity (ω). Participants emphasize the need to derive bound surface and volume charges, followed by calculating bound current densities to ultimately find the magnetic vector potential (A) and the magnetic field (B) as the curl of A. Key equations and concepts from Griffiths' textbook are referenced for guidance.
  • Understanding of electrostatic polarization in dielectrics
  • Familiarity with bound charge and current density calculations
  • Knowledge of magnetic vector potential (A) and its relation to magnetic field (B)
  • Proficiency in using Griffiths' Electrodynamics, particularly Example 5.11 and Problem 5.13
  • Calculate bound surface and volume current densities using J_b = ρ_b v(r) and K_b = σ_b v(r)
  • Explore the mathematical derivation of the curl of the magnetic vector potential (A) to find B
  • Review angular momentum concepts in rotating systems to understand the implications on magnetic fields
  • Study the effects of linear polarization in rotating dielectrics on electromagnetic fields
Students and researchers in electromagnetism, particularly those studying rotating systems, dielectric materials, and magnetic field calculations in advanced physics contexts.
thatmaceguy
Long dielectric cylinder of radius R carries a built-in electrostatic polarization P
that is linearly proportional to the distance to the axis, P=\alphar, P is directed along
the radius-vector r. Cylinder is being rotated around the axis with angular velocity
\omega. Find the magnetic field B on axis.
Conceptually I think I understand the problem, I'm just having a hard time (as usual) setting up the math.
Basically, I should be able to solve for the bound surface and volume charge, then find the bound surface and volume current from those bound charges and the angular velocity. After that I think I should able to find the magnetic vector potential (A) and finally B since it is equal to the curl of A.
I've been referencing Example 5.11 and problem 5.13 and from Griffiths but as I've implied, I have a really hard time assembling the actual math.
Thanks for any help/guidance you can give.
That sound like as good a plan as any...start with the bound surface and volume charges. What are the equations relating them to the polarization? Calculate them from those equations (show your steps if you get stuck!).
Hmm, yeah I meant to include that I had already done that in the original post. My apologies.
Here's what I have for that.
Surface Bound Charge = \alphaR (Alpha x R)
Volume Bound Charge = -2\alpha (-2 x Alpha)
(sorry, not terribly familiar with latex)
I am not certain though how to move forward from here.
Good.
Now you want to calulate the volume and surface current densities... \textbf{J}_b=\rho_b\textbf{v}(\textbf{r}) and \textbf{K}_b=\sigma_b\textbf{v}(\textbf{r})...so, what is the velocity of any given point in the cylinder if it is rotating with angular speed \omega?
