Calculate Binding Energy & Equilibrium Sep. of Na+/Cl- in NaCl
ptar
The question is;
The interaction energy between Na+ and Cl- ions in a NaCl crystal can be written as:
E(r)= -A/r + (B/r^8)
where A = 4.03 x 10^-28 J.m and B = 6.97×10^-96 J.m^8. The energy is given in Joules per
ion pair.
(a) Calculate the binding energy (E0) and equilibrium separation (r0)
between the ions. (b) Estimate the Bulk modulus.
I'm fairly sure that the equilibrium separation is calculated by setting dE/dr=0 and solving for r, so that should be easily done.
What I'm really confused about is how to find the binding energy? Also can't seem to find the relevant equation for estimating the bulk modulus.
Thanks in advance for any help.
What is binding energy? Hint: What is the potential energy when the two ions are "very far apart"?
For bulk modulus, you have dE/dr. What kind of quantity is that? Then, all you need is the density, which you should be able to intuite from the r0. Think in terms of "small perturbations".
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
