Program Overflow: Troubleshooting Tips
The discussion revolves around a code snippet for a binary tree insertion program that is experiencing issues, specifically an overflow error. The primary concern is that the program does not allocate memory for the nodes, leading to potential stack overflow due to infinite recursion. This occurs when the `insert` function is called repeatedly without reaching a base case, as the pointer `*p` never becomes NULL. Additionally, there is a critical flaw where the program attempts to assign values to `*p->left` and `*p->right` without first allocating memory for `*p`, which would result in a crash when trying to dereference a null pointer. The conversation highlights the need for proper memory management using `malloc()` to prevent these errors and ensure the program functions correctly.
ma12
my program is not working properly after taking values it gets overflow
#include<stdio.h>
#include<conio.h>
void insert(struct node**, int);
struct node *ptr;
struct node
int data;
struct node *right;
struct node *left;
void main()
int will , i , num;
ptr = NULL;
ptr -> data = NULL;
printf("Enter the Number");
scanf("%d", &will);
for(i=0; i<will; i++)
printf("Enter the Item",&num);
insert(&ptr, num);
getche();
void insert(struct node **p, int num)
if( (*p) == NULL)
printf("Leaf node created");
(*p) -> left = NULL;
(*p) -> right = NULL;
(*p) -> data = num;
return;
else
if( num==(*p) -> data)
printf("Entered repeated values rejected");
return;
if(num < (*p) -> data)
printf("directed to left ");
insert ( &((*p) -> left) ,num);
else
printf("Directed to right");
insert( &((*p) -> right), num);
return;
Technology news on Phys.org
Overflow of what, in which line.
in void insert
else
What does p point to?
And if you think the answer is "struct node", check out your code.
I don't see any mallocs() to allocate space for the structures.
Overflow probably means stack overflow. This usually means you got into an infinite recursion loop. In your code this is possible if you got into a situation where *p is never equal to NULL in insert(). If this happened insert() would keep calling itself forever, every call to insert() pushes a frame on the stack, eventually the stack overflows. One reason this might have happened is if you built a tree incorrectly such that there is a loop in it.
Also roger is right, if you ever somehow DID get to your "leaf node created" termination condition you'd instantly crash. You establish *p is NULL, then you assign to *p->left. If you write to or read from a null pointer you will crash (but the crash probably would not describe itself as an "overflow").
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
