Non-Linear Lever Examples: Get the Answers Here
  • Thread starter Thread starter shakdaddy
    Lever Non-linear
Non-linear levers can be better understood as cam mechanisms rather than traditional levers. For applications like stretching a rubber band with increasing force, a cam profile can be designed to achieve the desired effect. Resources available online can help in calculating the appropriate cam profile for specific needs. Practical experimentation using materials like cardboard or plastic is a common method for designing these mechanisms. Understanding the distinction between levers and cams is crucial for effective design in mechanical applications.
shakdaddy
Firstly, this is a great forum!
Maybe this is more of a mechanical engineering question, but ...
Can someone help give me some examples of non-linear levers? I want to be able to stretch a rubber band with factored-increasing force. Like a reversed camber on a compound bow.
I hope I asked this correctly. My physics vocabulary is limited- but improving with the help of this forum.
What you are dealing with is actually a cam rather than a lever. A quick Google should turn up lots of information about how to calculate the profile to fit your needs. I can't do math, so I always work mine out using cardboard or plastic pieces for mock-up trial and error design.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
