Doppler Shift Light from another galaxy
The discussion centers on analyzing the Doppler shift of light from a distant galaxy, specifically noting an absorption line at 1118 nm compared to 625 nm from the sun. This shift indicates that the galaxy is moving away from us, as the observed wavelength is longer. The initial calculations using classical Doppler equations yielded an incorrect velocity of approximately 44% of the speed of light. Participants suggest using the Relativistic Doppler Shift formula for more accurate results, as significant velocities require this approach. The correct formula involves the ratio of the wavelengths and the speed of light, allowing for a more precise determination of the galaxy's velocity.
Airman
When we analyze the light coming from a distant galaxy, we find a particular absorption line with a wavelength of 1118 nm. This same absorption line in light from the sun has a wavelength of 625 nm is this galaxy moving towards us or away from us?
Calculate the magnitude of the velocity of the galaxy relative to us.
I've tried all what I think are the Doppler equations for light, but can't seem to get the right answer.
When I plug in the values to λr = λc/(c − vr), I get 1.32198284 * 10^8 m / s, which the online homework says is wrong.
Bave you tried:
and
If the classical approach (as you have used) returns a value for the velocity that is a significant fraction of the speed of light (in your case about 44% of c), then you'll want to employ the Relativistic Doppler Shift instead.
λ_s/λ_r = sqrt((1 + beta)/(1 - beta))
where: beta = v/c
This can be rearranged as:
v/c = (λ_s2 - λ_r2)/(λ_s2 + λ_r2)
