Kramers-Kronig relationship between ultrasonic attenuation and phase velocty
The discussion focuses on the challenges of applying the Kramers-Kronig relationship to ultrasonic attenuation and phase velocity, particularly regarding the correct treatment of attenuation units. The user has encountered issues when using attenuation data in decibels per centimeter (dB/cm), leading to incorrect results, while data in centimeters yields accurate outcomes. There is uncertainty about the appropriate conversion methods for attenuation, with attempts made using different formulas like 10^(A/20) and 10^(A/10). The importance of ensuring that the final units align with the expected dimensions is emphasized, suggesting that the attenuation coefficient should have units of 1/(m-s²). The thread seeks guidance on correct unit conversions and data sources to validate results.
chauhan89
Hi Forum,
I am currently attempting to utilize http://bayes.wustl.edu/etj/articles/kramers-kronig.pdf" Unfortunately ... I have not been successful. I have tried for the past week and asked those around me.
All help is appreciated.
The equation is as follows:
( 1/c(w0) ) - ( 1/c(w) ) = 2/pi*( integral from w0 to w ; wrt dw')
the integrand is
alpha(w')/(w'^2)
Definitions
alpha ;known function for attenuation.
c ;function for speed
w0 ;known base frequency, speed known at this frequency
w ;variable frequency (chosen by me; I would use equation to solve for c(w) )
I believe the problem lies with the units I use for attenuation.
Attenuation data that is available in db/cm does not provide the correct results. This happens when I keep the attenuation in db/cm or do a conversion.
ie. A is db/cm. I use the value ==10^(A/20).
I do get correct results when I use attenuation data available in cm. (no db or anything).
So is my conversion wrong? Is there another way to treat attenuation? I have tried variations such as 10^(A/10), and made sure MatLab numerical integration is accurate, other unit conversions accurate, etc.
All help is welcome! :)
How are you able to tell whether your results are correct? Where are you obtaining the different types of data?
You obviously shouldn't use decibels. The final units should be sec/m since it is the inverse of speed. So the attenuation coefficient should have units of 1/(m-s^2) I think.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
