Eleventhstep
- 1
Hello, my name is Kevin and I going to be adding electricity to a barn about 1000ft away from my house. The barn will act as a second home and will need to be using around 2-10KWh. I figure it will never exceed 10KW per hour. I will be running it underground in heavy duty poly casing. My question is what gauge wire should i be using for such a long run? Given the run distance and Wattage requirements should i step up the voltage and then drop it back down at the barn? I can use either 220 or 110 in the barn.
Thanks
Thanks
