Why Does a Longer or Thicker String Produce a Lower Note?
A longer or thicker string produces a lower note due to its lower frequency of vibration, which is influenced by its mass density. The frequency of a vibrating string is determined by its tension, length, and mass density, with thicker strings having a higher mass density that results in lower frequencies. While a common belief is that a larger spring outputs less energy, the energy of a wave is primarily related to its amplitude rather than frequency. Therefore, waves of equal amplitude can have varying frequencies without affecting the energy transported. Understanding these principles clarifies why shorter or tighter strings yield higher notes.
1MileCrash
Why does a longer, or thicker string produce a lower note when plucked? What is it about the larger spring that causes a lesser energy output?
My common intuition says that a larger spring is harder to move and therefore will vibrate with lesser frequency, but I am not satisfied with that reason.
A longer / thicker string vibrates at a lower frequency and so produces a lower note.
What do you mean "that causes a lesser energy output"? A spring can only output, at most, the same energy used to compress it. The larger the spring (larger in the 'thicker wire' sense), the more energy to compress it and so the more energy it outputs.
Yes. My question is, why does a thicker string vibrate at a lower frequency?
I am also under the impression that a wave with a higher frequency carries more energy.
I'll start here for you, the energy of a wave is related to its amplitude, not frequency.
A good place for you to read up on the subject:
http://www.physicsclassroom.com/class/waves/u10l2c.cfm
The amount of energy carried by a wave is related to the amplitude of the wave. A high energy wave is characterized by a high amplitude; a low energy wave is characterized by a low amplitude.
Putting a lot of energy into a transverse pulse will not affect the wavelength, the frequency or the speed of the pulse. The energy imparted to a pulse will only affect the amplitude of that pulse.
I see, so waves of equal amplitude but with wildy varying frequency are transporting the same amount of energy per time period?
The frequency f produced by a stretched string is given by:
f =\frac{1}{\lambda} \sqrt{\frac{T}{\rho}}
where \lambda is the wavelength (and is fixed by the geometry of the instrument),T the tension in the string, and \rho is the mass density (mass/length). A thicker string has a higher mass density.
So it's possible to tension a thicker string to have the same pitch as a thinner string, but that introduces other issues- stress on the attachment points, for example.
Correct.
Thanks guys. Andy, i can't see the equation on the mobile theme but i will be sure to check it out.
What characteristics of a wave ARE effected by frequency? Or is frequency more of an effect than a cause?
One slight enhancement...
The energy of a _mechanical_ wave is related to amplitude. You may have been thinking of electromagnetic waves where the energy is proportional to the frequency. But that's a different fettle of kish.
why is it that the shorter the string the higher the note?
why is a tighter string make a higher note?
This has been answered by Andy Resnick in post number 6.
