Integration by Parts definite integral
The discussion revolves around the definite integral from 0 to 1 of the function \( \frac{r^3}{\sqrt{4+r^2}} \). Participants are exploring integration techniques, particularly integration by parts and substitutions, to evaluate this integral.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • One participant attempts integration by parts, expressing \( u \) and \( dv \) in a way that leads to a more complex integral. Others suggest using a substitution \( u = 4 + r^2 \) as a simpler approach. There is also a mention of using hyperbolic functions and questioning the application of integration by parts regarding the choice of \( u \) and \( dv \).
Participants are actively exploring different methods to tackle the integral, with some suggesting alternative substitutions and questioning the implications of their choices. There is no explicit consensus yet, but various productive directions are being discussed.
Some participants express confusion over the integration techniques and the resulting forms of the integrals, particularly regarding the differences between integrals involving \( a^2 + u^2 \) and \( a^2 - u^2 \). There is also a recognition of the complexity introduced by the integration by parts approach.
raptik
The definite integral of from 0 to 1 of ∫ (r3)dr/sqrt(4+r2)
∫udv = uv - ∫vdu
∫du/sqrt(a2 - u2) = arcsin(u/a) + C
∫du/(asqrt(a2 - u2)) = (1/a)arcsec(u/a) + C
I made u = (4+r2)-1/2
because I thought it easier to get it's derivative, rather than integral by making it dv.
du = -r(4+r2)-3/2dr
dv = r3dr
v = (1/4)r4
I've set up the equation as
= uv -∫vdu
= r4/(4(4+r2)1/2) + ∫r3dr/(4+r2)3/2
This seems somewhat similar to the the second equation I put in "Relevant Equations" (where I could put a two in the numerator and multiply the integral by (1/2), but both top and bottom are to the power of 3 (which I don't know how to get rid of. AND the bottom is not a2 - u2 but a2 + u2.If somebody could please help me understand this I would be greatly appreciative. I'd like to be able to master this type of integration, but I seem to have hit a wall.
It's a LOT easier if you just work it through with the u substitution u=4+r^2.
What about letting u=x^3 and v=1/sqrt(4+r^2): to obtain:
<br /> \int_{0}^{1}\frac{r^{3}}{\sqrt{4+r^{2}}}dr=\left[ r^{3}\sinh^{-1}(r/2)\right]_{0}^{1}-3\int_{0}^{1}r^{2}\sinh^{-1}(r/2)dr<br />
but according to integration by parts, 1/sqrt(4+r^2) must be dv not v, if you make u = x^3. Also I did not follow how you got the sinh^{-1}(r/2) if the denominator is (a2 + u2)1/2 not (a2 - u2)1/2
I see what you did for the most part, except that last issue I mentioned. Thnx.
Okay, look at the integral:
<br /> \int\frac{dx}{\sqrt{a^{2}+x^{2}}}<br />
Use the substitution x=a\sinh u and the integral reduces down to:
<br /> \int du=u=\sinh^{-1}\left(\frac{x}{a}\right)<br />
It's a standard integral
That was what hunt_mat meant.
That is exactly the point! If it were \sqrt{a^2- u^2}, then the integral would be sin^{-1}(x). But because it is "+" rather than "-" it is the hyperbolic rather than regular sine.
du = -r(4+r2)-3/2dr
dv = r3dr
v = (1/4)r4
= uv -∫vdu
The integral that resulted when you did integration by parts,
\int_{0}^{1}\frac{r^{3}}{(4+r^{2})^{3/2}}dr\,,\ is more difficult to integrate than the integral you started with:
\int \frac{r^{3}}{(4+r^{2})^{1/2}}dr\,.
This suggests reversing the roles of u & v to the extent that you can do that. Integrating (4+r^{2})^{-1/2} will result in something with a factor of (4+r^{2})^{1/2}. In fact, although this is a little unusual, you can pick what you want v to be, then differentiate that to see if the dv which results is usable.
Let \textstyle v=(4+r^{2})^{1/2}, then \textstyle dv=r(4+r^{2})^{-1/2}\, dr\,. This will work out just fine!
Therefore, let \textstyle dv=r(4+r^{2})^{-1/2}\,dr\ \ \to\ \ v=(4+r^{2})^{1/2}\,.
This leaves \textstyle u=r^2\ \ \to\ \ du=2r\,dr,.
\int u\ dv=\int (r^2)\left(r(4+r^{2})^{-1/2}\right)\,dr \text{, and } \int v\ du=2\int (r)\left((4+r^{2})^{1/2}\right)\,dr
The integral \int r\,(4+r^{2})^{1/2}\,dr is easily evaluated with a simple substitution.
  • · Replies 105 ·
10K
  • · Replies 22 ·
10K
