Rate of reduction of the volume of a raindrop
benzel20
I have trouble solving the following question, would someone offer some help? thanks.
In very dry regions, the phenomenon called Virga is very important because it can endanger aeroplanes. [See Wikipedia]
Virga is rain in air that is so dry that the raindrops evaporate before they can reach the ground. Suppose that the volume of a raindrop is proportional to the 3/2 power of its surface area. [Why is this reasonable? Note: raindrops are not spherical, but let's assume that they always have the same shape, no mater what their size may be.]
Suppose that the rate of reduction of the volume of a raindrop is proportional to its surface area. [Why is this reasonable?]
Find a formula for the amoung of time it takes for a virga raindrop to evaporate completely, expressed in terms of the constants you introduced and the initial surface area of a raindrop. Check that the units of your formula are correct. Suppose somebody suggests that the rate of reduction of the volume of a raindrop is prpoportional to the square of the surface area. Argue that this cannot be correct.
The volume of a sphere (and a falling rain drop is very well modeled by a sphere, not a "raindrop" shape) is given by V= (4/3)\pi r^3. Its surface are is given by A= 4\pi r^2. If you solve the second equation for r, you get r= \sqrt{A/4\pi} (r is positive, of course). Putting that into the first equation,
V= \frac{4}{3}\pi \left(\sqrt{\frac{A}{4\pi}}\right)^3
= \frac{4}{3}\pi \frac{A^{3/2}}{4^{3/2}\pi^{3/2}}= \frac{1}{(3)4^{1/2}\pi^{3/2}}A^{3/2}
and you can diferentiate that with respect to A.
Another way to do this, perhaps simpler, is to use the chain rule:
\frac{dV}{dA}= \frac{dV}{dr}\frac{dr}{dA}= \frac{\frac{dV}{dr}}{\frac{dA}{dr}}
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
