Solving the Stamp Problem: Finding the Greatest Amount for Perfect Change
  • Thread starter Thread starter armolinasf
The problem involves determining the greatest amount that cannot be formed using only 5 and 7 cent stamps. The proposed solution suggests that 23 cents is the highest unattainable amount. To prove this, two steps are necessary: first, demonstrate that 23 cannot be created using any combination of the stamps, and second, show that every amount greater than 23 can be formed. A hint indicates that only five specific amounts greater than 23 need verification to confirm the claim for all larger amounts. The discussion focuses on the mathematical proof required to validate the proposed solution.
armolinasf
If you have only 5 and 7 cent stamps you can make perfect change of a 5,7,10,15,17, etc. cent letter. You cannot mail a 1,2,3,4,6,8,9,11,etc. cent letter. What is the greatest amount that you cannot make perfect change for?
2.Attempt at a Solution
I'm pretty confident that the answer is 23 cents, however I want to be able to prove that that is in fact the absolute greatest amount for all possible combinations. Thanks for the help
There are two steps to proving it:
A. Prove that 23 cannot be made up of 5 and 7 cent stamps.
B. Prove that every number > 23 can be made up of 5 and 7 cent stamps.
A hint for the second part, only 5 numbers > 23 need to be checked to be sure it is true for all numbers > 23.
