Very simple problem about wavelength, just a double check on work
  • Thread starter Thread starter vande060
    Wavelength Work
The discussion revolves around calculating the wavelength and frequency of radiation given a wavenumber of 1200 cm^-1. The correct wavelength is determined to be approximately 8.33 x 10^-6 meters, and the corresponding frequency is calculated as 3.6 x 10^13 Hz. Participants confirm the calculations, noting that the definition of wavenumber can vary, but the provided solution is accurate under the assumption that wavenumber is defined as 1/λ. Clarifications about the context of wavenumber are discussed, emphasizing the importance of definitions in physics calculations. The final consensus is that the calculations are correct based on the given definitions.
vande060
radiation with a frequency of 1200cm^-1, calculate the wavelength in meters and the frequency in hertz
wavenumber = 1/λ
freq = c/λ
1200cm^-1 = 1/λ
λ = 8.33*10^-6 m
freq = (3.0 * 10^8)/(8.66*10^-6) = 3.6*10^13 Hz
wavenumber = 1/λ
freq = c/λ
1200cm^-1 = 1/λ
λ = 8.33*10^-6 m
Hi vande060.
Looks good to me, & I'm a spectroscopist.
(I assume that's 1200 cm-1 in a vacuum.)
Do you mean wavenumber?
wavenumber = 1/λ
freq = c/λ
1200cm^-1 = 1/λ
λ = 8.33*10^-6 m
I think that's right. :approve: But realize that depending on the context, wavenumber sometimes is defined as 1/λ and sometimes defined as 2π/λ. The above looks right to me assuming that you are using the wavenumber = 1/λ definition, and assuming that you mean the wavenumber is 1200 cm-1.
Thanks, both of you
if its wave number, then your answer is correct?
10K
