cooljoebay
- 2
I have converted my garage into a small studio with two rooms. Both rooms are completely airtight and isolated from one another. I am wanting to bring in fresh air and push out stale air simultaneously. I have installed a heater in the main room. Here is a basic concept that I figure could be made to work. First off, I know about HRV systems but this is much more simplistic.
The idea is to install an intake vent in the heated room that pipes in the fresh air from the attic area above by using a duct fan and possibly a filter. I figured that the room would already be somewhat pressurized and air easily "moved". So the intake vent would be low powered. Second, install a ceiling vent across the room since the heat rises and simply run an insulated duct up and over to the next room ceiling. The heat would enter the vent but I don't know if the intake fan would cause enough force to "push" the air through the ceiling duct down into the second room. Maybe I would have to install a second fan to help "pull" the heated stale air into the second room vent. Third, assuming thus far everything works, the stale out in the second room would have to go out. So, install another vent low on the wall of the second room to help keep heat from escaping badly, and to move the bad air on out back up to the attic.
Normally in a hrv system intake air is warmed before entering the room. But I figure that using a small fan and keeping the intake very gradual, this could solve the problem without caused much heat to be wasted. Maybe not even noticeable.
Two things that brought this idea to mind. Opening a front door of a house, causing the back door to push shut. Pressure? Also, when I was younger we lived in 2 story home and the only thing that heated the upstairs was open vents in the ceiling that allowed the rising heat to enter. It always worked out well.
Does anyone think this would work? Or am I clueless? lol.
