First and second order systems are distinguished by their order of derivatives and the number of boundary conditions required for solutions. First order systems have a single highest derivative and typically require one boundary condition, while second order systems involve a second derivative and need two boundary conditions. The assumption that first order systems are single degree of freedom (DOF) and second order systems are two DOF is incorrect; the classification is based on the order of the differential equation. Understanding these distinctions is crucial for analyzing dynamic systems effectively. Clarity on these concepts enhances the ability to solve complex engineering problems.
#1
Jones1987
74
What is the difference? I used to assume First order was a Single DOF system and a Second order was a 2 DOF system. Can anyone give me some clarity.
How did you find PF?: Via Google search
Hi,
I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere.
The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary
The bubble is formed at the tip...
Scenario 1 (figure 1)
A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material.
The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm).
At this level of stretch, the load cell reads 45N tensile force.
Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype.
There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/
but none that address the overall topic (unless I've missed...
