Calculating Flux from a Permanent Magnet
The discussion focuses on calculating the appropriate size of a permanent magnet for an alternator design, specifically determining the minimum thickness of a Neodymium magnet to achieve the desired voltage at a specific RPM. Key concepts include the Br rating, which indicates the flux in a magnetic circuit with zero reluctance, and the Hc rating, which defines the opposing magnetic field intensity. The B-H curve is central to understanding how adding an air gap or using an electromagnet affects the net flux in the circuit. The participant seeks to confirm if an air gap with a specific reluctance can be equated to using a coil to supply opposing flux, and whether swapping these elements would maintain the same total flux. The discussion emphasizes the importance of magnetic circuit analysis, akin to electrical circuit principles, in optimizing the design.
nickw1881
I am hoping someone here has experience with permanent magnets. I have a theory on how to size a permanent magnet for an alternator I am designing, and I want someone to confirm that my technique will yield a result that is useful enough to go through the expense of building a prototype. My goal is to find the minimum thickness of Neodymium magnet that will produce the needed voltage at the RPM I plan to run.
First, permanent magnets as I understand them: Permanent magnets have a 'Br' rating, which is the amount of flux that would flow if this magnet were part of a magnetic circuit with 0 Reluctance. They also have an Hc rating, which defines the opposing magnetic field intensity that would result in 0 flux in that same magnetic circuit. If Br is plotted as a point on the vertical axis, and Hc as a point on the negative horizontal axis, then the curve between them is the B-H curve.
The B-H curve (most of it) is drawn by reducing the net flux in the circuit by A) Adding an air gap that will store potential energy as a magnetic field, or B) Using an electromagnet to create an H-field that opposes the one from the magnet. It is my understanding that a magnetic circuit is roughly analogous to an electric circuit, in that Kirchoff's loop law can be applied to both.
****If I add an air gap that has a reluctance of 10 Ampturn/Tesla, and there is 1 Tesla flowing through the circuit from the permanent magnet, then is that air gap the equivalent to using a coil to supply 10 amp turns opposing the permanent magnet flux? If the air gap and coil were swapped, would the total flux in the circuit remain the same: 1 Tesla?****
By choosing my air gap and core material, I can know the reluctance of my magnetic circuit. I will take that reluctance, multiply it with the chosen flux density (flux needed to produce rated voltage@rpm) to get H opposing. Br is constant, no matter how thick or thin the magnet is, and since Hc is rated per unit length, I should be able to scale the H axis of the B-H curve to find the correct magnet thickness. It should be similar to how I would do per-unit calculations or normalized filter design in other EE calculations.
In magnetic circuits, the conserved quantity corresponding to electric current is magnetic flux. Where B is measured in Tesla, or Webers per square meter, then the flux, Phi is in units of Webers. \Phi = \int B \cdot dA_e The flux passing through any cross section of the magnetic circuit is the same when leakage flux is taken into consideration.
Another useful quantity, akin to Kirchhoff's voltage law is the integral of H around the loop. Magnetomotive force, NI = NI = \oint H \cdot dl_e. dl_e is an element of the magnetic path. NI is current times number of turns of wire. It is the equivalent of a voltage source. Unfortunately, I'm unclear how permanent magnets or magnetic reluctance might modify this equation.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
