Diff EQ - Heating and cooling w/ fluctuating outside temp
Indychus
Say we have a warehouse with a 5 hr time constant. The outside temp is 16C at 2:00AM, and 32C at 2:00PM. The warehouse is at 24C at noon. What will the temp be at 6:00 pm? When will the temp be 27C?
First, I set up a sine wave for the fluctuating outside temp. With x=0 corresponding to 2:00AM, my wave looks like
24-8\cos{\frac{2\pi}{24}
Here's where it gets fuzzy. From a similar example in class, we set up an equation of form
e^\frac{-t}{2}\{\frac{1}{2}\int{e^\frac{t}{2}[M],dt\}+C
where M is our wave representing the fluctuation of outside temp. The example from class had a time constant of 2 hours, I assume that's where the t/2, -t/2, and 1/2 in the above equation come from?
If I use that equation, but substitute 5 in place of the 2's, then perform the integration, I should be able to differentiate the result and find relative extrema to determine when my temps are at max/min, correct? I should also be able to drop the C (initial temp) term since it will eventually disappear due to exponential decay anyways, right?
so i would interpret the time constant as something like
\frac{dT(t)}{dt} = -5(T(t) - T_b)
where T_b is the outside temperature, this should be no problem to inetgrat e by separation of variables
rearranging, for the variable outside temp Tb(t) gives
\frac{dT(t)}{dt} +5T(t) = 5T_b(t) = 5(24-cos(2 \pi t /24))
I would attempt this by trial functions using the method of undetermined coefficients
http://www.efunda.com/math/ode/linearode_undeterminedcoeff.cfm
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
