Surface Tension of Water: The Effects of Syrup on Surface Tension
Syrup generally reduces the surface tension of water due to its impurities, which significantly affect interfacial energy. The impact on surface tension depends on the type of syrup, its concentration in water, and the temperature. The discussion references a video that suggests a strong surface tension could allow for unique effects, but it is acknowledged that adding syrup would likely disrupt this. Participants clarify that any additive, including syrup, would lower the surface tension compared to pure water. Overall, the consensus is that syrup cannot increase surface tension without contaminating the water.
KayEl9
Hello. I'd like to ask: does syrup increase or reduce the surface tension of water? Thanks.
What is the context of your question? Why do you ask?
Water is very sensitive to contamination- small impurities can have large effects on the interfacial energy- specifically, the interfacial energy will drastically drop.
If you are looking for a quantitative number, you have to be more specific- what kind of syrup? what is the ratio syrup/water? what temperature?
Well, I think I should've explained it in the question :)
I'm just thinking about the surface tension because of this video: http://www.youtube.com/watch?v=7ctaA2mERzI"
I think it could theoretically be possible if the surface tension was strong enough and not disturbed by things such as bubbles etc. And I was thinking if it would be more realistic if syrup (or something else) was added to the water. I just don't know if the syrup would increase or reduce the surface tension.
EDIT: Andy Resnick: So does the first line of your post mean that there isn't any substance that could increase the surface tension (because it would always mean polluting the water)?
You do realize the video is a trick/joke, right?
AFAIK, the interfacial energy of a solution is always less than the pure solvent.
Yes, I realize that. But that doesn't have to prevent me from thinking of the psychical side of it.
Anyway, thanks for your answers.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
