Can Strong Acids or Bases Have Negative pH Values in Practice?
  • Thread starter Thread starter MaximumTaco
    Ph
Strong acids and bases can indeed have negative pH values in practice, with examples like 10M HCl demonstrating a pH of -1. This phenomenon is not purely theoretical; superacids can achieve these negative pH levels. However, the range of pH values is generally considered to be between 0 and 14 for solutions that adhere to Ostwald's dilution principle. This principle indicates that while pH typically falls within this range, deviations can occur in very dilute or concentrated solutions, allowing for the existence of negative pH values under specific conditions.
MaximumTaco
Is it really possible to have strong acid/bases with a negative pH in practice, or is it purely theoretical. Like we say 10M HCl has pH = -1, does it really?
Is there something that limits the range of possible pH values for a solution?
Chemistry news on Phys.org
Yes it is possible and does happen, just browse yahoo and look up "superacids", you can easily have a negative pH of -1. And there are NO limits for a pH value.
Wolfson.
There is a law called Ostwald's dilution principle, and it states that pH is within 0 and 14 for solutions obeying this law. The response for pH with respect to concentration is somewhat deviated in very dilute and concentrated solutions.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
