What is the formula for calculating the weight of a plane in level flight?
  • Thread starter Thread starter ryanbe
    Airplane Physics
To calculate the weight of a plane in level flight using Bernoulli's principle, the difference in airspeed above and below the wing is crucial. The airspeed of 62 m/s on top and 54 m/s on the bottom leads to a pressure difference that can be related to the lift force. The calculations provided yield a lift force of approximately 9568 N, which corresponds to a weight of about 975 kg for the plane. It's important to note that this approach simplifies the complex dynamics of flight and assumes constant air density. Accurate calculations should also consider variations in airspeed and density relative to altitude.
ryanbe
hi
how do i calc the weight of a plane if it stays in level flight with the air speed on top of the wing 62m/s and the bottom 54m/s. the surface area of the wing is 16m^2
Google "Bernoulli's principle". You'll find that the excess pressure on the bottom of the wing (which you can relate to the weight of the plane, how?) is given by the difference in the kinetic energy densities above and below. The latter is the mass density times the velocity squared. You'll have to look up the density of air, so apparently the plane is not flying at high altitude.
(By the way, this is a cute problem, but it is not an accurate portrayal of the real reason that planes fly, as proven by the fact that this plane could fly upside down. But perhaps it is the maximally efficient flight, and maybe many planes are designed to get close to this limit. The other key design issue is stability.)
You'd need to know the mass of the affected air. Also the air speed over and under the wing won't be constant, it will vary depending on distance from the wing.
Maybe this is just a simplication of the real issue and just wanting you to use Bernoull as opposed to the actual and complex process of calculating lift.
Also air speed relative to what? It appears to be relative to the wing. Air speed relative to the ambient air would be less, or else this is a very large airplane.
yes i must use bernoulli but not sure how ?
anybody got the equation in the form that i must use it, then i can take it from there ?
is this right : p1+1/2*1.29*62^2 = p2+1/2*1.29*54^2
p1 + 2479.38 = p2 + 1880.82
p1 - p2 = 1880.82 - 2479.38
= -598
p = f/a
598= f/16
9568n = f
plane = 975kg
Looks good to me, though I didn't check the units. Best to include them to make sure.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
