Transient Thermal Analysis- Ansys APDL Help
The discussion revolves around performing a transient thermal analysis of a thin composite film using Ansys APDL, with specific temperature conditions over defined time intervals. The user seeks clarification on how to set initial temperature conditions and the implications of changing temperatures during the analysis. It is confirmed that the model is exposed to an environment of 505 K for 0.04 seconds before returning to ambient conditions, and the user needs guidance on how to run the analysis until a stable solution is reached. Additionally, there is a need to model four layers of composite materials with varying properties, including three shell elements and one solid element. The conversation emphasizes the importance of providing detailed information for effective problem-solving in forum discussions.
deveshp1
Hello All,
I have to do a transient analysis of thin composite film. Following are the requirements:
1. Time t=0 to t=0.01, Initial condition of Temperature=300 K.
2. Time t=0.01 to t=0.05, Temperature=505 K.
3. Run the analysis from t=0.05 until a stable solution is obtained.
I tried to read through the help file for load step options but couldn't understand where could i define such parameters.
Please help!
Thanks in Advance
Devesh
Why would the first "initial" temperature affect the evolution of the system after it has been reset with the second "initial" temperature? Perhaps I do not understand your description correctly. Are these initial conditions applied to the same regions?
Thank you for the reply.
Yes, The region is originally at ambient conditions and at time t=0.01 sec the it is subjected to a temperature of 505 K for the next 0.04 sec
What do you mean by "subjected"? Is it placed in an atmosphere of 505K for 0.4s? Or something else? And what happens after that?
One can make best progress on a discussion forum by providing as many relevant details as possible at the very beginning. That way it minimizes the time lost in going back and forth, trying to understand the problem.
I am sorry for the insufficient details. Yes, the model is kept in the environment of 505K for a period of 0.04 sec and then the atmosphere is suddenly removed. I have to run the analysis until a stable solution is obtained.
Also I have one more problem. I have to model 4 layers of composite materials out of which 3 layers are made of shell elements and 1 layer of solid element. All the layers have different material properties and thicknesses. How can I do that? All the layers have lXb the same.
Thanks for your help!
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
