Build a Solar-Powered Pool Pump: What You Need to Know
  • Thread starter Thread starter booter10ca
    Build Pump
A 5W solar panel is insufficient to directly power a pool pump, which typically requires more energy, especially for starting. To utilize the 5W panel, it can be used to charge a battery, which then powers a suitable inverter for the pump. The required power depends on the pump's horsepower; for instance, a 0.5 HP pump may need around 1 kVA peak for starting. Storing energy in a lead-acid battery and using a DC brush or brushless DC motor can be more efficient. Overall, careful planning of the system's components is essential for effective operation.
booter10ca
hey
i have a 5W pv panel and was wondering if i could build some sort of circuit to run my pool pump? was wondering what i would need ... any thoughts would be appreciated
Probably more than 5W.
Like skeptic said, I think you'd be hard-pressed to run your pump off 5W.
However, you could always use that 5W solar cell as a circuit to power a circuit that enables your pump.
thats what I am looking to do, i know 5w isn't enough but if there is some sort of circuit i can construct to harness the power in battery cells or some other form is what I am looking to try and do
Start by determining the HP required by your pump. IF it is say 0.5 HP, you will probably need 1 kVA peak for starting volt-amps in a 0.5 HP induction motor. Store the energy from the panel in a lead-acid battery, and use a 1 kVA inverter. The average power will depend on the duty cycle of the pump. You can probably get 10 watts per square foot for charging a battery system, or ≈0.1 kilowatt-hours per day per square foot. Use an inverter to get 60 Hz power from a battery. You might be better off with a dc brush motor or a BLDC (brushless dc) motor, because the starting VA requirement is less.
Bob S
Bob S
Thanks alot
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
