Use Reciprocity Relations to Find Fourier Transform
erok81
Use the reciprocity relations and known transforms to compute the Fourier Transform of the given function.
f(x)=\frac{1}{1+x^{2}}
With the help of the table of Fourier transforms, write the given functions as F(f).
First off my text just starts using that capital F symbol but never really says what it is. I am assuming that is the Fourier Transform?
The hint gives me
\sqrt{\frac{\pi}{2}}e^{-| \omega |}
I am just assuming again, since that is the Fourier transform from the table, it is also F(f)?
If that is right, I can now move onto the reciprocity portion. First...nowhere in my book mentions anything about these. But it does give another hint.
Reciprocity relation: F2(f)(x) = f(-x) where F2(f) = F(F(f)).
Is my F(f) term correct first? If so, then I am not sure what this hint even does for me.
If I had something like f(g(x)) I can do these because I have a known variable to work with and swap in the different functions. But with F(F(f)) I have no idea what that means let alone can solve it. :redface:
That's about where I am so far. Not much at all unfortunately. Any ideas or hints to get moving on this problem?
Yes, it is the Fourier Transform.
Note that the result is again a function, but now from a different variable, usually k, omega, or xi. Apparently in your case omega has been chosen.
erok81 said:
The hint gives me
Actually, this is your final answer (with omega as the chosen transformed variable).
You can see this for instance here:
http://www.wolframalpha.com/input/?i=fouriertransform[1/(1+x^2),+x,+\omega]
Yes, you formula is correct.
To know what this hint does for you, you need to check your table of known transforms.
Are there any entries of the form e-|x| or e.g. 1/(1+k2)?
If you need more information about Fourier Transforms, you can look e.g. here:
http://en.wikipedia.org/wiki/Fourier_transform
http://mathworld.wolfram.com/FourierTransform.html
Don't you have a textbook that explains a little more about it?
Thanks for the reply.
I think I was confused because it seemed to be a two part problem. I find the transform in the table then use reciprocity relations to find the transform. In my answer I just pulled the transform from the table and was done.
Yep...there is an entry for e-|x| which results in √(2/Π) a/(a22, just like your post.
The book gives...
g=F(\frac{\pi}{2}e^{-|x|}), ~F(g)=(\frac{\pi}{2}e^{-|\omega|})
Now that I type out that answer I think I am seeing where the hint comes into play. Except my table gives it in ω so I am already there like you said.
Thanks for posting this as well. I do have a text but it didn't say much about this problem. The links will help though.
The book gives...
Well, you're not quite there yet.
There's a difference between the Fourier Transform and the Inverse Fourier Transform.
That is, you can not simply swap x and omega in the formulas.
That is why you still need to combine the formula from the table with the reciprocal theorem...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
