Calculating Force of a Small Potato Cannon
The discussion revolves around the construction and performance of a small potato cannon made from PVC and steel, focusing on the calculation of force generated by the combustion of hairspray as fuel. A key inquiry is whether there is a maximum point of fuel beyond which additional hairspray does not increase power due to limited oxygen availability. Participants suggest that force varies as the projectile moves through the barrel, indicating the need for calculus to express force as a function of time or distance. They propose using momentum and energy equations to calculate force, noting that energy calculations may be less reliable due to losses from friction and heat. Understanding these principles can help optimize the cannon's performance.
jameslat
Hello,
I built a small potato cannon out of PVC pipe/steel. It's 15.5 cm long, and about 7.6 cm wide on the inside. It's made of 2 parts the barrel and combustion chamber (or as i refer to, "the death chamber"). the "death chamber" is cylinder about 7.6 cm long and 7.6 cm thick.
and the barrel is about 7.6 cm long but it's only about 2.5 cm thick so as to allow a great deal of pressure to be focused on the projectile. I use hairspray as my fuel.
Is there a maximum power point in which after a certain amount of hairspray, it won't matter how much more is added because it will still give the same results?
(assuming I know the Velocity initial when it comes out of the barrel) How can I calculate the force that the the fuel is causing?
(would it be a momentum equation like p=(mass of projectile)*velocity , but how would i incorporate the length of the barrel?)
Please help put me on the right track and,
Thanks so much for your time,
-James
jameslat said:
Hello,
You'll shoot your eye out, kid.
I'm not a combustion chemist, but I would guess yes since there is only so much oxygen in there.
Force must vary as potato goes down the barrel. So it isn't really correct to say "the force". If you can write force as a changing function of time or distance, calculus can be used. Otherwise you can talk about the "average force". Then question arises "average over what? distance or time?". I think (Force)(Time) = (Mass)(Velocity) would apply if Force was the average force over time. However, you're more likely to know the distance down the barrel that the time it took the potato to travel that distance.
So you might use Work = (Force)(Distance) = Kinetic Energy = 1/2 (Mass)(Velocity squared). The drawback is that energy equations are less reliable than momentum equations since energy gets lost as friction, heat etc.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
