How does a cathode ray eject inner orbital electrons?
Cathode rays, composed of high-energy electrons, can excite or eject inner orbital electrons from atoms through energy transfer mechanisms. Despite both being negatively charged, the high kinetic energy of cathode rays allows them to overcome the electrostatic repulsion and interact with electrons in the target atom. This interaction can lead to phenomena such as dielectric breakdown and x-ray emission when sufficient energy is imparted. The term "pull" refers to the ability of these energetic electrons to disturb the atomic structure, facilitating electron ejection. Understanding these interactions is crucial for applications in spectroscopy and other fields.
joebobjoe
(Since this is a coursework question and not a homework question, I deleted the template)
Both my chemistry and physics textbooks cite cathode rays as having the ability to excite or eject electrons from an atom (e.g., dielectric breakdown, x-ray spectroscopy). How can a stream of negatively charged electrons pull other negatively charged electrons away from an atom? This seems counter-intuitive to me. Any explanations would be helpful.
P.S.: I've already checked Wikipedia and Google.
Why do you think they can't push them away from the atom? Why do they have to 'pull'? If they have enough energy they can disturb them in one way or another.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
