Difference equations and z transforms.
  • Thread starter Thread starter cdotter
    Difference
The discussion revolves around solving a difference equation using two methods: undetermined coefficients and z transforms. The specific equation is y[n+2]-y[n+1]-6y[n]=n, with initial conditions y[0]=0 and y[1]=-1.
  • Mixed
  • The original poster attempts to solve the difference equation using both undetermined coefficients and z transforms, expressing concern over discrepancies in their results. Some participants question the accuracy of the z transform table used, while others suggest revisiting the professor's notes for clarity.
Participants are exploring different methods to verify their results, with some guidance provided on the z transform process. There is an indication that the original poster may have resolved their confusion, as they mention figuring out a misunderstanding related to their professor's notes.
There is mention of potential errors in the z transform table and the original poster's repeated attempts to solve the problem, indicating a struggle with the material. The initial conditions and the requirement to verify solutions across methods are also noted.
cdotter
y[n+2]-y[n+1]-6y[n]=n; y[0]= 0, y[1]= -1
Solve using method of undetermined coefficients and z transforms to verify the answers are the same.
Undetermined coefficients:
Let [itex]y=r^n[/itex]
[itex]r^{n+2}-r^{n+1}-6r^n=0[/itex]
[itex]r^n(r^2-r-6)=0 \Rightarrow r=3, r=2[/itex]
So the homogeneous solution is [itex]y_h[n]=c_1 3^n - c^2 2^n[/itex].
For the particular solution:
[PLAIN]http://img199.imageshack.us/img199/8694/giflatex.gif
(For some reason it says there's an error in my code when I try to use the embedded Latex system...)
Solving for coefficients c_1 and c_2 with the initial values, I get c_1=-31/36 and c_2=-8/9.
So [itex]y[n]=-\frac{31}{36}3^n+\frac{8}{9}2^n-\frac{1}{6}n-\frac{1}{36}[/itex].
Z transform
Taking the z transform of both sides of y[n+2]-y[n+1]-6y[n]=n gives
[itex](z^2yz-z^2 \cdot 0 - z \cdot -1)-(z(yz-0))-6(yz)=\frac{z}{(z-1)^2}[/itex]
[itex]yz(z^2-z-6)+z=\frac{z}{(z-1)^2}[/itex]
[itex]y[n]=\frac{z}{(z-1)^2(z+2)(z-3)}-\frac{z}{(z+2)(z-3)}[/itex]
Taking the inverse z transform in Maple gives me
[itex]-\frac{3}{20}3^n-\frac{8}{45}2^n-\frac{1}{6}n-\frac{1}{36}[/itex]
So where did I go wrong? I've redone this problem a few times now and I keep coming up with the same incorrect answer.
Maybe my z transform table is wrong? I have
[itex]n=\frac{z}{(z-1)^2}[/itex]
[itex]y[n+1]=z(yz-y[0])[/itex]
[itex]y[n+2]=z^2yz-z^2y[0]-zy[1][/itex]
I think I figured it out. I must have misunderstood my professor's notes. For anyone who cares I'll write it up.
Taking the z transform:
[itex]z^2X(z)-zX(z)-6X(z)=\frac{z}{(z-1)^2}[/itex]
[itex]X(z)=\frac{z}{(z-1)^2(z+2)(z-3)}[/itex]
Take the inverse z transform of this gives me:
[itex]-c_1 (-2)^n+c_2 3^n-\frac{1}{36}-\frac{1}{6}n[/itex]
Plugging in the initial values and conditions I get:
[itex]c_1=-\frac{8}{9}, c_2=-\frac{31}{36}[/itex]
Or:
[itex]y[n]=-\frac{31}{36}3^n+\frac{8}{9}(-2)^n-\frac{1}{6}n-\frac{1}{36}[/itex] which mirrors my first solution.
