Canonical Transformations, Poisson Brackets
UniPhysics90
This isn't actually a homework problem, but a problem from a book, but as it's quite like a homework problem I thought this forum was probably the best place for it.
Consider a system with one degree of freedom, described by the Hamiltonian formulation of classical mechanics in terms of the coordinate q, and the canonically conjugate momentum, p. A canonical transformation is applied, such that the transformed Hamiltonian is described in terms of the transformed coordinate Q and the transformed momentum P. Explain whether P will be canonically conjugate to Q, and how Poisson brackets may be used to check this.
P will be canonically conjugate to Q (it says so in a book!) and possibly that Poisson brackets will give a constant value (books seem to suggest either 0 or 1?). If anyone can explain this further I'd really appreciate it!
Thanks
As far as I remember, we have for a canonical transformation
\{q,p\}=\{Q,P\}=0,
and
\{q,q\}=\{Q,Q\}=\{p,p\}=\{P,P\}=1,
i.e. the Poisson brackets are conserved in a canonical transformation.
Even if this property isn't directly mentioned, I found the wiki article on canonical transformations quite good: http://en.wikipedia.org/wiki/Canonical_transformation"
I guess the fact that the Poisson brackets are conserved is a consequence of the fact that the dynamics aren't changed in a canonical transformation.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
