What are the informations deducible from hubble diagram of supernova 1a?
humanist rho
What are the informations deducible from Hubble diagram of supernova 1a?
Space news on Phys.org
The relationship being determined is luminosity distance vs. redshift. Different cosmological models with different values of Ω0 and ΩΛ predict different forms for this relation. In particular, models with non-zero ΩΛ tend to have luminosity distances that are larger at any given redshift (meaning that objects appear systematically fainter than one would expect in the zero lambda case).
Luminosity distance is the distance inferred from the inverse-square law for intensity of light. In other words, it is the distance measure obtained by assuming that this law holds true. Luminosity distance may not correspond to physical distance due to the expansion of the universe, and curvature, if any.
EDIT: Forgot to mention that since SNe Ia are standard candles (at least reasonably so, we think), determining luminosity distances for them is easy, and since they are quite luminous, this can be done out to very large redshifts, provided you do a coordinated survey to search for them.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
