Root test vs. ratio test question
cue928
I am doing the following practice problem in prep for an exam:
sum from n=0 to infinity: (3^n)/(n+1)^n
The book says to use the ratio test on it, which I did, but would the root test also apply to this?
The root test applies, and in fact is probably the simplest test to use in this case. What was your conclusion based on the ratio test?
Well...
\sqrt[n]{\frac{3^n}{(n+1)^n}} =
I had initially changed it to be:
(3/(1+n))^n. Applying the nth square root, I got lim n approaches infinity 3/1+n = 0.
Ok, so what's the conclusion?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
