GRE question: Young's Double Slit Experiment
AriAstronomer
Consider a young double slit experiments where the two slits are spaced d = 0.1mm apart. If when the screen is at a distance of l=1m the first bright maximum is displaced y = 2cm from the central maximum, then find the wavelength of the light.
dsin(theta) = m(lambda)
I use the small angle approximation, tanx = sinx = x = y/D.
dy/D = m(lambda), where d = 0.1mm, D = 1m, y = .02m, m=1, and I get lambda = 2000nm, but the solution manual says that the answer is 5000Angstroms. They say lambda =[ d/l ]*(dy) = [(10^-4)/2 ]*(10^-2), but I don't really see where they're getting these numbers from. Any idea?
Nope, but your solution is perfectly correct. The author probably screwed up and used the wrong numbers in writing the answer key.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
