How could one measure degree of coherence with Fresnel birprism?
Measuring the degree of coherence with a Fresnel biprism involves understanding the relationship between visibility and spatial coherence, similar to the Young Double Slit experiment. The key point is that both setups create interference from different parts of the same wavefront, allowing for the assessment of correlation between spatially-separated points. When varying the width of the source in a Fresnel biprism, the virtual sources also change, which may impact visibility measurements. The sampling occurs at the entrance face of the biprism, analogous to the pinholes in Young's experiment. Understanding these dynamics is crucial for accurate coherence measurement in optical experiments.
BrunoIdeas
How could one measure degree of coherence with Fresnel biprism?
Hello. I have some questions about the study of partial coherence with a Fresnel biprism.
In common text degree of coherence and its relationship to visibility is introduced considering a Young Double Slit experiment.
At the same time, in basic texts, the Fresnel biprism is introduced as an equivalent to Young's wave-front split interferometer.
HOWEVER, when studying partial coherence one measures visibility of fringes produced by a Young interferometer BECAUSE one is studying to correlation of the fields AT PINHOLES. Therefore giving information about the relationship between to laterally spaced points of the field. I don't see how this could happen with a Fresnel biprism and my question is:
1) Which two points, pinholes, or regions of space am I referring to, if any?
Although I am mainly interested in this first question, I pose another one.
2) In a Young experiment if one varies the width, for example, of the source, the pinhole dimensions stay the same. In Fresnel birprism when the width of the source varies so do the virtual sources. Won't this affect meausres of visibility?
I am seeing this differences and probably I am not considering/understanding something.
Thanks in advance to everyone.
If I understand your question, the pair of pinholes and the biprism are equivalent because both create interference between different parts of the same wavefront.
http://www.pbjacquemin.com/images/scanning_device3.gif
http://www.physics.umd.edu/lecdem/services/demos/demosm5/m5-24.htm
Young's interferometer measures the spatial coherence of a wavefront- how well different spatially-separated portions of a wavefront are correlated. A Michaelson interferometer measured the temporal coherence: how well different temporally-separated portions of a wavefront are correlated.
So, to your question #1, you are sampling the wavefront at the pinholes or the entrance face of the biprism. For #2, I haven't used a biprism so I can't say for sure.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
