What Is the Maximum Value of r(n-r) for Composite Functions?
  • Thread starter Thread starter vkash
vkash
If the composite function f1(f2(f3(...(fn)))) n times, is an increasing function and if r of fi's are decreasing function while rest are increasing, then find the maximum value of r(n-r)?
How can i attempt if i don't know what is question.
I request you to not put answer!. I want that you just tell me question in easy language. I want to try it before anybody tell me it's answer. If you give example then it will easy to understand.
Say you have n=3 functions. If all of them are increasing, the composite function will be increasing, and you'd have r=0, so r(n-r)=0. You can also get an increasing composite function when r=2, in which case, you'd get r(n-r)=2. The other two cases will result in a decreasing composite function. So when n=3, the maximum value of r(n-r) is 2.
The problem is asking you to do this for the general case. I'll leave it to you to figure out what combinations will result in an increasing composite function.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
