How Does a Solar Cell Operate in Forward Bias?
A solar cell operates in forward bias by allowing electrons to flow from the N-side to the P-side, where they recombine with holes, but this process is less intuitive than in a standard diode. In photovoltaic operation, the junction remains forward-biased, diverting diode current from the load and typically operating around 0.45V at room temperature. The efficiency of solar cells is limited by the requirement for photons to have energies greater than 1.12eV to generate electron-hole pairs, with sunlight providing even higher energies. Potential improvements for solar cells include using materials with better energy gaps suited for sunlight, stacking materials to capture different light energy slices, and concentrating light to enhance current and voltage while reducing semiconductor area. Cooling the cells is also crucial, especially when sunlight is concentrated, to improve overall efficiency.
macca77
My question is basically how can a solar cell operate in forward bias?
A normal diode in forward bias (with a battery connected) drives electrons from the N-side towards the pn junction where they are continuously recombining with holes (reducing the depletion zone and allowing for the flow of current).
A solar cell seems less intuitive though. When in forward bias the electrons travel the opposite way. They go out the external cicuit which connects to the p-side, where the recombine with holes.
It seems strange to me that both of these are essentially in "forward bias" however the electrons are esentially traveling the opposite way, similar to that of a diode in reverse bias.
The junction is forward-biased in normal photovoltaic operation, and the resulting diode current is diverted from the load so it should stay small, meaning that a silicon PN cell must be operated around 0.45V at room temperature, even less at heat.
Though, photons must have >1.12eV to produce a pair, and Sunlight has even higher energies. This explains why Solar cells are inefficient. The quantum photon-to-pair conversion alone would be extremely efficient.
Improvements include:
- Gap energies better matched to Sunlight, like InSb or GaAs materials ( spacecraft prices)
- Stacks of materials that harvest each one slice of light energy
- Concentrated light produce more concentrated current, allowing a higher voltage. Better: it saves semiconductor area.
- Cool the cells. Especially if Sunlight is concentrated.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
