Q is closed under division or not?
8 replies · 6K views · last reply
flyingpig
Q = rational numbers
My professor proved that it is closed under addition yesterday. I kinda understood a bit...
Proof
Let [tex]r_1, r_2, \in \mathbb{Q}[/tex]
[tex]r_1 + r_2 = \frac{m_1}{n_1} + \frac{m_2}{n_2} = \frac{m_1 n_2 + n_1 m_2}{n_1 n_2} \in \mathbb{Q}[/tex]
By letting [tex]m_1 n_2 + n_1 m_2 = m_3[/tex] and [tex]n_3 = n_1 n_2[/tex]
Since [tex]m_1, m_2, n_1, n_2[/tex] are integers, [tex]m_1 n_2 + n_1 m_2, n_1 n_2[/tex] are also integers.
So that
[tex]\frac{m_1 n_2 + n_1 m_2}{n_1 n_2} \in \mathbb{Q}[/tex]
How the heck does it work for when n_1 or n_2 = 0?
Take a look at the first line. There we take [itex]r_1,r_2\in \mathbb{Q}[/itex]. Then we say that
[tex]r_i=\frac{m_i}{n_i}[/tex]
but obviously this doesn't work for [itex]n_i=0[/itex] since division by zero is not defined in [itex]\mathbb{Q}[/itex].
That is [itex]\frac{m}{n}\in \mathbb{Q}[/itex] if and only if [itex]n\neq 0[/itex]...
I thought it is the same logic for integers, I take 1 and 0 and take 0 to be the bottom, can't do that.
If I take 0 and 1 and put 0 on top, that works, but it is an exception when it is the bottom?
But the whole close division thing i can take two integers (including 0)?
No, an element of [itex]\mathbb{Q}[/itex] is defined as a fraction [itex]\frac{m}{n}[/itex], where n is nonzero. So you can't take 0 is the denominator, by definition.
You can't divide by 0.
No. The integers are not closed under division for reasons other than the fact that 1/0 is undefined.
Is 4/3 an integer?
Perhaps you should review the definition of a 'ring'.
Is 4/3 an integer?
Thank you, you just added more work for me...
Anytime! You're welcome.
To help out a bit more:
Whether we're discussing the Integers, the Rationals, the Reals, or Complex Numbers (all with the usual arithmetic operations):
It's always true that 0 times any element is 0, 0 being the identity element for the addition operation. Because of this, there is no multiplicative inverse for 0, and thus division (the operation that is the inverse of multiplication) by 0 is undefined. Therefore, when discussing whether division is closed, we exclude the case of division by zero.​
