Terrestrial phenomena significantly influenced by GR?
  • Thread starter Thread starter Loren Booda
    Gr Phenomena
Loren Booda
What natural terrestrial phenomena are significantly influenced by general relativity?
When I lift my legs up I fall down?
The sky is dark at night?
Garth
Just about everything.
How about affect on electromagnetic phenomena?
Atomic clocks are sensitive enough that they "tick" noticably different depending on their elevation. There is a coordiinate time known as TAI time that is defined by averages the contributions of many different atomic clocks - it is necessary to correct for the altitude of each contributor.
Also, the issue of defining a coordinate time over the Earth's surface involves considerations of General Relativity since the Earth rotates. If you transport a clock around the rotating Earth, it won't read the same as a clock that stayed behind, no matter how slowly. This was actually done in a famous experiment.
Well,sure. All the hydogen atoms in my brain have a multiplet 'fine structure' (spin-orbit interaction) at every level except l = 0 which is due to relativistic effects. In fact, all of the heavy atoms have an even greater energetic split which is even more noticeable, and at an energy level which can only be determined precisely with full (mental) relativistic treatment.
Maybe that's why they say I have a split personality. Well, at least they can't say I'm degenerate. :smile:
However, these are only SR effects.
For GR effects you'll have to capture & measure the electromagnetic emissions (from my nuclear cranial radioactive decay) at several different terrestrial gravitational potentials and notice the resultant gravitational doppler shifts.
(Please don't reveal your findings. )
Creator :biggrin:
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
