Signal to Noise ratio dB levels
The discussion focuses on understanding the dB levels calculated from signal power in noisy and non-noisy conditions using the SNR formula. It clarifies that dB measurements are ratios, with SNR typically calculated as 20*log10(signal power/noise power). The conversation highlights that the interpretation of dB levels can vary, as they may refer to different contexts like sound or signal strength relative to a standard. A good SNR ratio is dependent on the specific system and its tolerance for noise, which can influence bit error rates in digital systems. Overall, the thread emphasizes the importance of correctly applying the SNR formula and understanding the context of dB measurements.
rama1001
Hello,
I have some 10 signals in noisy and nonoise(noisy+good) situations. I just calculated the power of each signal in two cases and then used SNR formula for dB(10log noisy/nonoise).
Now, I got noise levels in dB's. Here, i confused that these dB levels are referred to sound dB levels or some other dB's. Because, My teacher told me after seeing the achieved values(20dB, 32dB, 14dB...upto 10 signal values) and he said it was full noisy.
I am pointing here that what is these dB values and is there any chart for good and bad noise dB values or any information about this is appriciated.
A few points.
DB measurements:
In general, dB measurements are ratios (and in the application you listed they always are). So if you have a dB measurement that was 10dB that means that you had one thing that was some amount greater than the other. For SNR you are measuring the ratio of two powers so you use the equation 20*log10(x/y) which means that if you had a 10dB difference, x was 10x greater than y or if you had 20dB difference then x was 100x greater than y etc. The 20 comes from the fact that your actual equation is 10*log10(x^2/y^2) where x and y are signal amplitudes but you can pull out the square using the properties of logarithms.
At other times dBs are used to give strength relative to something. For example dBm is commonly used for transmission powers and this is decibals relative to a milliWatt. So in this case you use 10*log10(x/1mW). The y term from above is always fixed and the number you get gives you an idea of scale of how much stronger or weaker the signal is relative to a mW.
On SNR:
As I explained above the typical SNR equation is 20*log10(signal power/noise power). From what you stated above I wasn't sure if you were clear on that. To estimate the noise power you either have to measure it, make assumptions about it, or try to extract it if you have clean signal and then signals with noise.
What is a good SNR to ratio? That depends on your system and the amount of noise you can tolerate. For digital systems you can use SNR to calculate your bit error rate (BER). Usually for a given system you establish what an acceptable BER is and then work backwards to what your SNR needs to be and that tells you what you need to do in that signal's transmission.
For analog signals you also have to consider the application in a somewhat similar manner.
Sorry for the wrong information, I forgot that i used 20log(p1/p2). Thank you so much for such a good explanation.
Shouldn't it be 10*log10(signal power/noise power) or 20*log10(signal voltage/noise voltage)?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
